02-11-2020 11:37 PM - edited 01-05-2022 10:36 AM
02-13-2020 08:59 PM
yes. thanks
@trobious wrote:Hi dboxtvinfo715,
There is one more thing that was not mentioned. The person you referred must already have a sim card. They need to register with Public Mobile and activate their sim card in order to use your referral code. If a person who has no sim card clicks on your referral link, you will not get any benefit unless that person writes down your referral code and actually uses it during the activation process.
Cheers,
trobious
02-12-2020 04:48 AM
Hi dboxtvinfo715,
Cheers,
trobious
02-12-2020 02:16 AM
@dboxtvinfo715 If you activated aa new acount you will recieve a $10 credit within 72 hours. Otherwise as explained you will recieve a $1 monthly reward that should appear in your rewards section immediately.
02-11-2020 11:43 PM
@computergeek541 thank you for removing.
02-11-2020 11:41 PM - edited 02-11-2020 11:42 PM
To answer your question. If you refer someone to public mobile give them your referral code to use.
You will get $1 off per 30 days as long as the person's account is active and in good standing.
The person that you referred will get $10 sign up bonus within 72 hours.
02-11-2020 11:39 PM - edited 02-11-2020 11:39 PM
First please click the 3 dots on right side of your post and edit the post to delete your personal information ( referral code)..as it's visible for the public to see.
It's against the terms to show your referral code.. please delete it
You also have to click your badge top right..click profile... scroll down to pictures and delete it from there as well.
