Will this phone work on Public Mobile?
Greg45
The phone explicity says it "does not support the telecom CDMA 2G 3G network".
It also says it works on:
Network: GSM850/1800/1900mhz 3G
WCDMA850/1900/2100mhz 4G
Wondering if this will work on Public Mobile?
Sorry, that's all the info I have.
Jb456
What's the model of phone??
Dunkman
@Greg45
It should work for talk and text.  Data should be okay also... doesn't have all the bands tbough...
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
sheytoon
@Greg45 yes it will work just fine on 3G WCDMA.
Staliger
@Greg45 Should be okay for PM.
Doomsday
Make sure to compare your phone model with public mobile compatible phone list.
