Options
10-20-2022 02:00 AM
Currently my reward is saving dollars. If i change to another plan, will the reward keeps the same? thanks
Labels:
Rewards
2 REPLIES 2
Options
10-20-2022 10:26 AM
thanks
Options
10-20-2022 02:05 AM
@ben2018 wrote:Currently my reward is saving dollars. If i change to another plan, will the reward keeps the same? thanks
Rewards will stay the same.
![](/skins/images/34AB3B0FE78BBE11DBF186F131BC3766/responsive_peak/images/icon_anonymous_message.png)
