Will 5g plan work with 4g tower?
Kim6020
If i get a 5g data plan will it work when I visit a rural area that has only a  4g tower?
Or will a 4g data plan work better if there is only a 4g tower in the area?
@Handy1 wrote:
@Kim6020  yes absolutely and you should still get better speeds of 100mbs 4G plan do speed test to confirm
Speed test
https://www.speedtest.net/apps
your phone will drop to 4G if it can’t get 5G signal but still shouldn’t faster speeds the 4G plan being on 5G plan @Kim6020
I would suggest giving advice to run this app. Speed Test app is more for fun than anything else  I've used up more than 1GB in single test (I did it deliberately because I was near the end of my billing cycle), it could actually be harmful to give advice such as this.
Kim6020
Thank so much for the tips 🙏
Jedi1
Yes, my son’s phone is not 5G capable and he is on the 5G plan.  His phone is set to LTE and he does get a little more speed than he would on a 4G plan.  When we signed up, it was the better priced plan for him.
Speed test
