02-27-2020 08:02 PM - edited 01-05-2022 09:41 AM
Does wifi data used kept separate from the data included in the plans (ie. 4 GB wifi data used but only 1GB regular data so only need plan for 1 GB)
05-24-2020 12:01 PM
Yes, wifi usage is separate from data usage - though sometimes you might be eligible for a data promo too, which would have a separate meter in your usage section!
02-27-2020 09:14 PM
Yes Wifi data is separate from the cell phone plan data. Your wifi data usage DOES NOT affect your cell phone plan data consumption.
02-27-2020 08:09 PM
To managed Data plan:
Default to stop using mobile data and Only activate Mobile Data when you're NOT in WiFi zone. To turn it on/off in your phone's settings. (On iPhone, tap the “Settings” icon, tap “Cellular,” then turn on or off “Cellular Data.” On Android, tap the “Settings” icon, tap “Network & internet,” tap “Mobile network” and turn on or off “Mobile data.”)
02-27-2020 08:09 PM
@Parksrl wrote:Does wifi data used kept separate from the data included in the plans (ie. 4 GB wifi data used but only 1GB regular data so only need plan for 1 GB)
Wifi data does not count towards your plan data.
If you require 1gb or less data plan then the 25$ plan will fit you best. It gives you unlimited canada wide mins, if you set up auto pay you will 500mb + 500mb bonus for setting up auto pay
Im always connected to wifi i only use plan data when i have to or if wifi is not available.
Cheers
02-27-2020 08:08 PM
02-27-2020 08:05 PM
Wifi comes off of your internet. Data from you phone plan @Parksrl .
02-27-2020 08:03 PM
Wifi does not use your plan data.
