Plan compatibility
Parksrl
Do these plans work with Samsung J3 prime? J3 listed but not J3 prime
2 REPLIES 2
@Parksrl
The phone is SIM compatible.
The phone is radio compatible. Missing some LTE bands so it won't be awesome mobile data rates, but the bands it does support will be enough for Public Mobile's "3G speeds" across 4G/LTE radio.
It won't work if it's carrier-locked. A T-Mobile/Metro device from USA might be locked. If you're not sure then test if it works with another SIM card from a friend's phone.
And it won't work if it's blacklisted (reported as lost/stolen, etc).
geopublic
@Parksrl  Yes they do. Smiley Happy
