06-26-2020 01:43 PM - edited 01-05-2022 11:51 AM
My wife lost her iPhone X in the ocean today (no joke) ...
I have an older iPhone here, and an old SIM card I used for pre-paid for a short while (for an extra for babysitters)
When I log into her account, and try changing SIM to the spare one I have here (that is not in use) I get the following:
"Sorry, the SIM card number is invalid or already in use."
Is there any way I can have this SIM reset (as it is not in use and hasnt been for months) ?
Thoughts?
06-26-2020 01:54 PM
Thank you.
Off to get a new SIM locally (The sheer panic of her without a phone is kinda comical 😉 )
Thanks all !
06-26-2020 01:52 PM
@vacek wrote:I should not have to create a new account, with a new email address ...
There is an option to "Change SIM card" in her account ...
Under what conditions will this work ? Do I simply need to purchase a new SIM , do the change sim card in her account and her number will then be associated with the new SIM ?
@vacek Yes that is correct.
Still, no way to use the PM SIM I already have on hand ? Unfortunately no.
06-26-2020 01:51 PM
You won't be able reuse a previously activated sim. You can purchase a new at canadiancellsupplies.ca.
06-26-2020 01:48 PM
06-26-2020 01:47 PM
@vacek wrote:My wife lost her iPhone X in the ocean today (no joke) ...
Thoughts?
@vacek Unfortunately you cannot use a previously activated SIM card . You will need to purchase a new sim card access your wife's selfserve and select the change sim card option.
06-26-2020 01:46 PM
Thoughts?
If the old sim was for Public Mobile and has been Suspended for 90 days or more, then that account has been closed for good. You'll need a new sim to start a new account with a different emaail address.
