07-18-2017 10:58 AM - edited 01-04-2022 02:22 PM
07-18-2017 03:00 PM
07-18-2017 11:10 AM
What phone are you using? some phones lg g4 and G5 typically requre a factory reset.
If you are a new customer did you set up your APN settings?
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Setting-Up-Data-On-Your-Phone/ta-p/26
07-18-2017 11:01 AM
Here's a troubleshooting checklist for data problems, courtesy of @Luddite:
http://productioncommunity.publicmobile.ca/t5/Discussions/No-data-near-Renewal/m-p/134842/highlight/...
07-18-2017 11:01 AM
I've chosen the 90 days plan (3G+3G Bonus, unlimited International test & unlimited provincial talk) for $126. And I find out data doesn't work.
07-18-2017 11:01 AM
Here are 3 steps i recommend you do:
1) Double check data is included in your plan in self-serve. Who knows maybe the system glitched
2) Double check you have data turned on
3) Check APN settings for your phone
