04-10-2024
11:33 PM
04-11-2024
12:50 AM
computergeek541
The oldest? I received the new free 30G data that cannot be used first. Why can't we choose which bonus data to use after our monthly data is used up?
04-11-2024 11:24 PM
Thanks all. I checked my account. My 150 day Bonus data still remains unused since I got it. Is it because my regular plan data was not fully consumed by the end of the month?
04-10-2024 11:48 PM
04-10-2024 11:40 PM - edited 04-10-2024 11:40 PM
@bugsy7 - The bonus loyalty data will be used first - the closer the expiry - it gets set as priority. That is what I think.
But yes, the bonus loyalty data will be used #1, then your more is merrier bonus #2.
Also do not go to a plan of lower value then you will lose 100% of your bonus loyalty data!
04-10-2024 11:39 PM
FYI...if you're thinking about downgrading to a cheaper plan now...be advised that is you change to a plan of lower value than your current plan, you'll forfeit that 150 day Bonus data.
04-10-2024 11:35 PM
the special 150-days data bonus will be used before your other non-expirying data bonus you earned from before
04-10-2024 11:35 PM
according to Customer Support, the 150 day Bonus data will get used when your regular plan data is consumed.
