11-11-2018 06:10 PM - edited 01-05-2022 02:28 AM
Hi,
Where do I get my pin number? There seems to be no option for that anywhere.
11-12-2018 08:50 AM
Hey @bharathyp,
as of you have not done so already, please send us a private message. One of the moderators will be able to help you 🙂
Cheers,
Mary
11-11-2018 07:08 PM
"Where to get my pin number?"
In the future when you are asking questions or asking for help...please provide more detailed info.
PIN # related to what?
there are various different pin# used on cell phone systems.
11-11-2018 06:33 PM
You picked the account PIN number when you activated your Public SIM card/account. You should have received a text from 611 when you activated on the first day. Maybe check your old text message. Otherwise, you will need to contact moderator (as described above), but expect 3-5 day wait these days for moderator help.
11-11-2018 06:12 PM - edited 11-11-2018 06:13 PM
@bharathyp wrote:Hi,
Hi,
Which pin are you talking about? Are you being asked for a pin to unlock after inserting the PM sim card into your phone?
If you are then you will need to contact your previous carrier or the phone manufacturer to get the code.
If either response to your particular request leads to the resolution of your issue , please help other community members by marking that post as the solution. Thank You
11-11-2018 06:11 PM
You set up your pin number when you created your account. To change it you need to contact mods.
How can you get help with your account, activation, or service?
In your message please include:
Don't know your pin?--provide any 3 of the following:
How long until they reply?:
Some good posts/reads:
