When will a mod respond to me?
buffguy
I have a sim card from before the promo period, and I activated my phone, but need to be switched over to the 4gb/month promotion plan. I have messaged public mobile on facebook since saturday, I have emailed them since tuesday, and I have messaged the mods since tuesday, and there is no response?
This is very poor service, they should be trying to message everyone at least within a 48 hour time frame.
@nyall wrote:
Make enough of a scene and you'll get a reply within hours..
Worked for me. They prioritize their replies according to importance.
@nyall  They dont prioritize according to how much of fuss you make.
@buffguy  They will get to you, just going to take time.  Worth it in the end.
Rockdaddy22
Or, you could just make a civilized thread, describe your problem in detail and I'm sure it'll get solved soon.
nyall
princessmoo
I'm having the same issue! so frustrating.. I waited for more than a week already, still no reponse.
Chaos_Scorpio
there is a big backlog. expect delays.
Did you provide them will all of your account info and what you wanted?
If you still have service I wouldnt worry about it. They will apply the change and apply and differences.
I had my plan swap fail, it was fixed.
Rockdaddy22
You don't think they're trying? They are, it's just they're swamped with service issues. Do you have service? What plan do you currently have and when does it expire?
http://productioncommunity.publicmobile.ca/t5/Announcements/Moving-forward-together/m-p/105074#U1050...
