6 hours ago
When I entered my address it kept being auto generated incorrectly. The area code was correct. But the town and street was wrong.
How do I change it ?
6 hours ago
Some people might need a full address for their payment records for tax purposes. There is no city menu, the entire address is in on data field. Try updating your address, it might give you some insight on how to assist other customers struggling to get it to work.
6 hours ago
Don’t worry about the city. It takes the postal code in consideration and not too much about the city. Just pick the closest large city near you.
6 hours ago
@Marjax , updating the full address can be quite difficult. I have only been able to successfully do it using the app with location permission enabled and app cache deleted. The system does not accept user input unless it's been verified by the built in location service which seems to be very finicky. Keep trying with the app, it will eventually work.
