WhatsApp on BB Z-30
ahsan_khan_46
 I am  keep getting the message from WhatsApp  on my Black Berry Z-30
that  they will  not support BB and some other cell phones as of Dec 31, 2016
Should I worry for my BB Z-30 ??
I would appreciate for any help to clear this confusion
Thanks for your help and advice
Ahsan Khan
ahsan_khan_46
Thanks for the help
BB Z-30 is running on 10 OS version 10.2
So I guess this unit shouldn't have any problem running
Whtasaap after 2016
Ahsan Khan
mimmo
Whats app might still work on bb z30 but probably not,  it will definatly not be getting any updates.
google watsapp and blackberry z30 there are many results.
"While these mobile devices have been an important part of our story, they don't offer the kind of capabilities we need to expand our app's features in the future. This was a tough decision for us to make, but the right one in order to give people better ways to keep in touch with friends, family, and loved ones using WhatsApp. If you use one of these affected mobile devices, we recommend upgrading to a newer Android, iPhone, or Windows Phone before the end of 2016 to continue using WhatsApp."
http://crackberry.com/whatsapp-end-support-all-blackberry-versions-end-2016
mikga
https://www.whatsapp.com/faq/en/bb/20951501
Which BlackBerry devices are supported?
As announced in our blog, WhatsApp Messenger will no longer be supported on BlackBerry OS and BlackBerry 10 by the end of 2016.
Until then, we support any BlackBerry device that meets the following requirements:
  1. The BlackBerry is running one of the following operating systems: OS 7+.
  2. The BlackBerry is subscribed to a full BIS (BlackBerry Internet Service) data plan.
Note: The BlackBerry Priv and DTEK50 are supported Android devices.
Learn about supported devices on: Android | iPhone | Windows Phone | Nokia S40 | Nokia S60 | BlackBerry 10
Cheers,
WhatsApp Support Team
