02-24-2024 09:24 PM - last edited on 02-25-2024 01:21 AM by computergeek541
Whats the pin for esim? I want to lock it and need the default pin to set a pin.
02-27-2024 08:20 AM
That’s true, I probably don’t need it. I just like the extra security if my phone is stolen my phone password should be enough and the eSIM obviously can’t be removed. Thanks
02-25-2024 01:21 AM
@kylebunga wrote:Whats the pin for esim? I want to lock it and need the default pin to set a pin.
My suggestion would be to use a finger print lock and long phone PIN/password on your device.
02-25-2024 01:19 AM - edited 02-25-2024 01:20 AM
@Dunkman wrote:Not sure if it is necessary to lock your eSIM. Not a common request.
For physical PM SIM card before, I believe that 1234 was the default code.
I can confirm that Public Mobile uses 1234 as the default physical SIM card PIN. Some other carriers (example Wind Mobile Canada) used 0000 as the default.
02-24-2024 09:40 PM
