Number port failed
james123123
My number port said it failed. But I’m positive the account number I input was correct. I was able to receive the text message to confirm the number change from Fido.
not sure what my next steps should be.
thanks
2 REPLIES 2
@james123123
Yes, account number is a safe way for porting request.  But   did you reply YES to the port authorization text from your old provider within 90 mins ?  You can contact porting support team to confirm the porting status
@james123123  Does Fido sim still work ? I’ll send you the porting team number private message . Give them a call they can give status update on the port or retrigger it if needed. Will also leave you with this direct link to support should they be needed
send  a  private message   To CS_Agents
