What is the SIM card PIN?
Gunner44
15 REPLIES 15
@RosieR wrote:
@Luddite wrote:
@RosieR FYI: As shipped PM SIMs never require a PIN to function. The code 1234 is ONLY needed to "unlock" the SIM in order to lock the SIM with a PIN.
@Luddite I'm sorry if that is the case, why would the moderator even mention the default code 1234?  You said "The code 1234 is ONLY needed to "unlock" the SIM in order to lock the SIM with a PIN."  What does this mean?
If you want to lock your SIM, you will be asked for a code to do so. That code is 1234 UNLESS someone has already locked the SIM. This is to help insure you do not inadvertently lock your SIM. Presumably, the moderator thought the customer wanted to lock their SIM.
@RosieR wrote:
... why would the moderator even mention the default code 1234?  You said "The code 1234 is ONLY needed to "unlock" the SIM in order to lock the SIM with a PIN."  What does this mean?
The phone software won't let you change a PIN (to lock security settings you or your software decide to impose) until you enter the existing PIN. The SIMs aren't locked - they can be freely accessed on any device - but they still need to have a default PIN to assure maximum compatibility with device-side software.
Gunner44
Thanks for the help it worked.
A customer won't need the sim card's PIN to start using it. For the phone to prompt for it, someone would have had to enabled that sim card's security features to require it to use the service, or someone would have to go into the settings to either enable that feature or request to change the PIN.
@Korth wrote:
@CS_Agent wrote:
The default pin for all Public Mobile SIM cards is 1234.
That's amazing! I've got the same combination on my luggage!
LOL that's funny @Korth  😀
@Gunner44 wrote:
Did not work now what?
@Gunner44 I understand why it is confusing.  Go with what @CS_Agent says first as they worked for Public Mobile.  Use the 1234 default pin first.   Then if that doesn't work, your phone must still be locked so contact your former service provider for the unlock code.
Come back and tell us what happens.  Good luck.
Welcome to Public Mobile and the Community!  Cheers!  1
CS_Agent
Customer Support Agent
@Gunner44
Does it say you need a SIM card pin or a Network unlock pin?
If it's says Network unlock pin, you have to unblock your phone by reaching out to the carrier that sold it.
If the SIM is locked than you will a PUK code to unlock it - PUK :
  • Can be used to unblock a SIM card after 3 incorrect (consecutive) attempts to unlock either PIN 1 or PIN 2.
  • If the incorrect PUK is entered 10 consecutive times, the SIM will become unusable and the customer will need to obtain a new SIM and complete a SIM swap.
You can get the PUK from the mods by creating a ticket via Simon(the ? at the bottom right of the screen).
Public Mobile Moderator Team
Gunner44
CS_Agent
@Gunner44
Hi @Gunner44 ,
Is your phone locked to the previous provider? You need to contact them to unlock it (it is free of charge to do this).
gblackma
@Gunner44  its one message that you get if your phone is locked to the previous provider.  Contact them and ask them to unlock it for you. You will need your imei number dial *#06# to get it. .  If its a Samsung phone contact Samsung online and ask them to unlock it for you. Stay safe.
