What happen to existing number after porting in a new number?
clim
I got an existing number in my PM account right now and I'm thinking of porting in another number I have from Telus. If I do that, what will happen to my existing number at PM? Will it get replaced and I'll lose that number? Is there a way to keep both numbers?
Also, does the new ported over number inherit the plan in the PM account?
1 REPLY 1
neilselden
Hi,
When you port a number:
1) Your existing PM number is replaced by the number you are porting in
2) Your TELUS account would be closed
So, no.  You would not keep both numbers if you port your TELUS number to PM.
Cheers,
Neil
