08-15-2023 10:57 AM
I have charges on my log for phone numbers I never called and data I never used? Anyone else see this in their log?
08-15-2023 11:07 AM
That explains it thank you
08-15-2023 11:00 AM
Hi @Wooly
if the number ends with 4001 or 4002, that is a Voicemail number
usually calls to VM are not counted, they just there for record
but if you are on a $15 plan, calling from your phone to check VM will be counted for outgoing minutes
08-15-2023 11:00 AM - edited 08-15-2023 11:03 AM
there's no extra "charges" with PM. Voicemail numbers look something liked 40o4.4001
