06-26-2019 10:57 AM - edited 01-05-2022 05:35 AM
Anyone else’s plans and add ons tab from the self serve website not working? Also on the change phone number section when entering a used number and hitting the check number button, I’m getting an error on both with same message..
06-26-2019 03:06 PM
Might your internet connection be down possibly? And are you logged in on here via cellular network?
06-26-2019 02:57 PM
Are you getting any error messages at all?
06-26-2019 02:53 PM
Thanks tried that and even other computers and iphones but no luck
06-26-2019 02:51 PM
Try what dunkman and triguy suggested. Clear browser cache and or try using different browser. It worked for me.
06-26-2019 02:22 PM
I can't even get into my account !! Just comes up blank. I think theres something major wrong. Hope they can fix or have to look for new provider.
06-26-2019 11:17 AM
I've found the MyAccount webpages to be clunky and unreliable since I've joined PM. Often extremely slow to load (and therefore prone to time out). It's pretty shoddy overall, but it reflects the priority that Telus places on the brand.
06-26-2019 11:07 AM
Hi @Greg1275 , I just logged in to My Account right now to check and I received the same error message when I clicked at the Plan & Add-Ons tab. Sometimes the self-serve account page does that but it should be back up and running soon. I've only been with Public Mobile this month and it happened to me a few times where the My Account page is not working. But the Community site seems to be working all the time so that's good. Hopefully it'll work again soon.
06-26-2019 11:06 AM
Clearing cache worked, thanks guys!
06-26-2019 11:03 AM
Try clearing your cache and use a different browser.
06-26-2019 11:01 AM
Website is more finicky and slower since last night.
Might want to try in another 30-60 minutes. Or try a different web browser, clearing cache or incognito mode. Chrome incognito works well.
06-26-2019 11:01 AM
Ok thanks, will check back in, in a little bit.
06-26-2019 11:00 AM
Most likely unplanned service update/outage. Try again later.
This happens somewhat regularly.
