06-20-2024 06:51 PM
So far my experience has been really, really bad. Is Public mobile always like this?
06-20-2024 07:05 PM
Thanks. I contacted them. Hopefully this does something.
06-20-2024 07:03 PM
use this link to send a message to Customer Support. Give them as much info as you can..ie: ph number, PM acct #, name on acct, PM pin #, date you activated etc...
watch the little envelop icon on top right side of page will be highlighted when they respond.
06-20-2024 07:00 PM
I can't login to the web portal without getting an error "A1 Forbidden", and I can't login to the app either. There is no clear way to contact customer support.
Currently my phone cannot make or receive calls.
I think something must have gone wrong during the signup, but there doesn't seem to be a path to fix it. Really bad impression for a new customer.
06-20-2024 06:55 PM
a bit more detail of your vexation would help. Where did it all go so rong ?
