01-13-2025
07:45 PM
01-13-2025
08:03 PM
computergeek541
Hi ..
my name is xxxxxxxxxxxxxxxxxxxxxxxxx
by mistake I have changed my subscription from 11$/month to 30$/month
and I want my previous subscription or I will leave public mobile because it’s too much 30$ I found other deals with other companies but I would like to ask you first if you can return my previous subscription?!
01-13-2025 08:05 PM - edited 01-13-2025 08:07 PM
@Zaytuna wrote:Hi again..
I need a cheapest subscription, my current plan is 30$/month .
do you have cheaper one ?
First @Zaytuna If you did your research you should know that NOBODY from Public Mobile works on these boards. We are ALL customers like you.
When did you accidently change to the $30 account?
01-13-2025 07:58 PM
hi @Zaytuna
you can only change to plan available on your My Account. So , login My Account and go to Change Subscription page and check what cheaper plan you see.
01-13-2025 07:55 PM
Hi again..
01-13-2025 07:52 PM
sorry @Zaytuna
$15 plan is no longer available and you cannot change it back
