04-17-2023
02:21 PM
04-18-2023
09:43 AM
Dunkman
Some of my texts are going through, some aren't. All different people with different phone types and different phone providers. These people cant contact me at all. No calls go through for these people either. I NEED HELP and the bot dosent help... i need to speak to someone.... this is crazy i am not getting half my texts!
04-17-2023 02:36 PM
HI @Vern8748
are you sending text or iMessage/RCS? please check
Also, try to reboot the phone once.
And if you need help from Agent to check, please open ticket at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
04-17-2023 02:24 PM
@Vern8748 Here’s how to submit ticket if you need supports help
Watch for reply top of page to the
Right ( envelope image )
04-17-2023 02:23 PM
@Vern8748 Did you just port your number over to PM or are you a customer for some time? Have you tried a reboot of your phone just to try that? All of PM support is online so if a simple reboot doesn't work, you could always contact the CS Agent.
You can contact an agent using the chatbot. Type "agent" and click contact us to go through the wizard.
If for some reason they don't respond to the ticket, you can try to send an email directly to the CS Agent here.
Here is a help article about how to contact the CS Agent.
04-17-2023 02:23 PM
@Vern8748 another customer just post regarding text issue.
He did this and work , try to change the Preferred network type or network mode to 3G and see if it works
