Voicemail
Seco
Voicemail notification won't clear.
Deleted all messages, cleared data/cache, left myself a voicemail and deleted it but the notification is still there. Is there any way to clear it or disable voicemail services
darlicious
@Seco
If you have tried "everything" then try resetting your voicemail pin # via your self serve account.
To contact customer support :
Submit a support ticket via Simple--Simon the chat bot Click here
Or if you prefer or cannot submit a support ticket you may send a private message : Click here
To pre-verify add in your private messaging only your full name, address, email, phone # & 4 digit account pin #
JL9
If you have an iphone this seems to do the trick
https://iphone-tricks.com/tutorial/1555-how-to-turn-off-voicemail-on-iphone
@Seco  - maybe you would be interested in this to 'disable' voicemail:
https://productioncommunity.publicmobile.ca/t5/Getting-Started/Re-Disable-Voicemail/m-p/213805/highl...
Have you restarted your phone, or tried to a reset of your device's network settings?
To fix stuck voicemail notification on Android phones, Try -forced stop the notification. Press and hold the notification. A small box will pop-out. Tap on “force stop”.
HI @Seco   are you taking about the number to the top right of the icon , badge count?
If so, tell us what kind of phone you have and the Android or iOS version
