03-29-2022 05:12 AM
Just today my voicemail stopped working. I have tried resetting my passcode and i was told my 10 didget phone number was my temporary password. Nothing is working.
Phones
03-30-2022 09:55 AM
That's what the community is for 🙂
03-30-2022 07:27 AM
Thankyou to everyone who gave me advice about getting into my voicemail. I used the voicemail phone number updated my pin number and got into my voicemail. Again Thankyou all so much.
03-30-2022 06:39 AM
I cannot retrieve my voice messages anymore
03-29-2022 12:15 PM
Try calling 1-778-580-4001. I wonder if Public is doing things to their list of voicemail access numbers list. A few days ago there was a problem with 902.
03-29-2022 12:15 PM
@Jenny9 wrote:Just today my voicemail stopped working. I have tried resetting my passcode and i was told my 10 didget phone number was my temporary password. Nothing is working.
HI @Jenny9 what is "stopped working"? are calls not going into voicemail if you missed them? or you login and cannot retrieve the voicemail? can you confirm what you meant by not working
03-29-2022 12:11 PM
Is your voice mail full?
03-29-2022 09:37 AM
Did you try accessing your voice mail trough other phone calling access number? Have your voice mail pin ready to enter.
I doubt resetting password will help and yes, default password is your phone number.
03-29-2022 06:05 AM
Customer Support Agents can help. There are 2 ways to reach them:
- Create a support ticket by clicking here , then type Support Ticket, then select Contact Us, then select the topic that more closely matches your request. Then click Click here to submit a ticket , or,
- Send a private message to them by clicking here
You’ll see their reply in your Community private mailbox in the envelope to the left of your avatar.
03-29-2022 06:04 AM - edited 03-29-2022 06:06 AM
@Jenny9 - so it was working prior to this?
Reboot your phone see if that helps.
If not, perform a Reset of your device's Network Settings. This also resets Wi-Fi networks and passwords, cellular settings, and VPN and APN settings that you've used before.
Iphone:
To Reset Network Settings, begin by opening the Settings app. Next, tap General -> Transfer or Reset iPhone -> Reset -> Reset Network Settings. and enter your passcode.
Your iPhone will reset network settings and restart itself.
android:
Find and tap Settings > System > Advanced > Reset options > Reset network settings.
If still issues remove / delete your voicemail contact from your contact list completely and add it back into your contacts.
You may wish to add the local one to you in your area found in this Voicemail Access list:
edit, in case you have never set it up before, or some steps here may help:
https://www.publicmobile.ca/en/on/get-help/articles/set-up-voicemail
