Voicemail
RandyPickup
I pay monthly and it will not activate
@RandyPickup  - have you restarted your phone lately?
Also, you can try to perform a Reset of your Network Settings.
This also resets Wi-Fi networks and passwords, cellular settings, and VPN and APN settings that you've used before.
Iphone:
To Reset Network Settings, begin by opening the Settings app. Next, tap General -> Transfer or Reset iPhone -> Reset -> Reset Network Settings. and enter your passcode.
Your iPhone will reset network settings and restart itself.
android:
Find and tap Settings > System > Advanced > Reset options > Reset network settings.
If still issues, delete any voicemail contact number you have in your phone, then re-add it.
You may wish to choose one that is localized to your area listed here:
https://productioncommunity.publicmobile.ca/t5/Using-Your-Service/Updated-list-of-Voicemail-Access-N...
JL9
Do you get any message or automated response at all? I just activated today and left a test vm. I just now accessed VO I email and had the automated public Mobile message walking me through setup. All of that went smoothly and my only issue is using a 100% automated greeting. If you aren't getting that at all or dead air when you try to access your voicemail, it may be something that needs to be escalated for sure.
darlicious
@RandyPickup
Here's the link on how to set up your voicemail. If you encounter a problem we will help you figure it out.
https://www.publicmobile.ca/en/bc/get-help/articles/set-up-voicemail
