Voicemail
ksmith
I just switched to Public Mobile. When I pressed and held 1 to access my voicemail my phone asked for a VM #.  I entered my telephone # but now whenever I press and hold 1 it takes me to my VM message - like I was calling my # not my personal voicemail box.  How do I fix this?
I assume the voicemail # I entered was incorrect but I do not know how to clear it.
My phone is a Samsung Galaxy S8.
@alabon wrote:
Je crois qu'il suffit de taper * très vite après avoir entré le mot de passe. J'ai eu le même problème au début. Le menu vocal est à mon avis déficient d'un point de vue interface de l'utilisateur.
I used google translate for this (English)
I think you just have to type * very quickly after entering the password. I had the same problem at first. The voice menu is in my opinion deficient from a user interface point of view.
alabon
RobertQc
Did your voicemail issue get resolved?
RobertQc
@ksmithHello and welcome to public mobile 🙂
Press Phone.
Press the menu icon.
Press Voicemail settings.
Press Voicemail number.
Please enter this number in your Call Settings >> Voicemail >>Setup:  +16475804001
 You can also when you get to your own voicemail press the * key, then enter your password to access your menu, which is how you would normally access your voicemail by calling from an outside / landline
