08-31-2023 09:49 AM
09-08-2023 01:52 PM
That's a workaround but it shouldn't be necessary to do it that way. The standard method of accessing voicemail is to long press the 1 key on the dialer. Somewhere down in the dialer settings should be the voicemail access number that makes that work. If you have an iphone it's a dial code.
09-08-2023 09:40 AM
Morning @Celine_Hopkins
happy that it works 🙂
09-08-2023 08:41 AM
This worked as a solution for me. I have now saved the Nova Scotia voicemail access number into the contacts on my phone and it works like a charm. Thanks everyone!
08-31-2023 09:55 AM
place your phone on airplane mode, then acquire another device from a friend or family member.
Call your number, press the star button when you hear your voice announcement.
Enter your voicemail password.
Does that work?
08-31-2023 09:54 AM
if Press and hold 1 does not connect you to Voicemail, go to the Dialer settings and set the voicemail access number there
you can set the number to 1-778-580-4001
or pick any number from here
08-31-2023 09:51 AM - edited 08-31-2023 09:51 AM
you press 1 and didn't work?
Try to call yourself from another phone and press * and see if you can access
08-31-2023 09:50 AM - edited 08-31-2023 09:51 AM
@Celine_Hopkins Press and hold 1 on the dial pad
