Voicemail notifications
Ynwa97
I'm new to Public Mobile and have noted that, unlike my previous provider, I don't receive a text notifying me that I have a voicemail. Is this possible with PM and, if so, how do I set it up. Thanks in advance.
MoeT1
You just have to go to the voicemail, and go to where the automated voice says "you have 1 new message" it should have the option to delete the number. Happy surfing and I hope it works out for you! 🙂
slusagm
The device notification is a device feature only.  And PM does not have SMS notification for Voicemail message
Chalupa_Batman
Hi @Ynwa97
I guess it really depends on your phone. I know with my iPhone, the voicemail red dot shows up. I guess you must have an Android?
