Voicemail notifications not working iPhone 12 pro
ZoeDog
Ported I’m from Koodo iPhone 12 Pro latest software and is.
not getting any voicemail notifications.
have reset network, reset iPhone and reloaded.
verified notifications enables, and have tried a new eSIM ($5)
Hold 1 in voicemail and listen and erase all voicemails.
and still not working
ZoeDog
Yes I have check daily, nothing for this issue in inbox only in my sentbox.
Thanks @Handy1  for quick reply.
@ZoeDog  Are you checking your community inbox for their reply . Use this link to it to se their reply
ZoeDog
I had followed advise and reached out to  support 2 weeks ago, and have yet to receive a response.
Debating porting out as missed a few important calls without knowing there was voicemail with time sensitive replies.
ZoeDog
Thanks, I have contacted support and just waiting a response for reseting voicemail.
LitlLdy
@ZoeDog , you did right by resetting your network settings which normally fix a few issues but didn’t for you! 😞
eSIM shouldn’t affect your voicemail notifications.
I know the older iOS software affected the voicemail notifications at one point but with updated iOS 16.6 it is no longer an issue for me!
Please use @Handy1 suggestion to ask a CS_Agent to reset your voicemail on their end.
@ZoeDog  I think this is a iOS issues . But some have had luck asking support to reset the voicemail also . So here’s the link to support
send a  private message   To CS_Agents click
