09-13-2020 08:42 PM - edited 01-05-2022 03:52 PM
When I try to access my voicemail, I get the message "that I don't have an active long distance add on and this call is not covered by my plan". But my plan includes Canada wide calling!
09-13-2020 09:52 PM
@Rhonda5 wrote:When I try to access my voicemail, I get the message "that I don't have an active long distance add on and this call is not covered by my plan". But my plan includes Canada wide calling!
With the potential of possibly bing out of minutes mentioned earlier, there could also be a provisioning issue with the account. If you dial your voicemail number without a 1 in front of the area code, it's possible that you might hear a message about possible long distance charges, but after that listening to that message, the call should complete. The message about the call failing means that there's something else going on.
09-13-2020 08:47 PM
@Rhonda5 hi are you on the limited minutes plan if so you could be out off outgoing minutes this could explain why you can't check your voicemail
09-13-2020 08:47 PM - edited 09-13-2020 08:49 PM
@Rhonda5 dial ##21# then ##004# and try again
nevermind if you're on a limited minutes plan you most likely used all your min
you can purchase the $5/500min add-on.
either add $5 to your account and then purchase the add-on
or
apply the addon twice
