06-14-2023 06:29 PM
Hello! Is anyone having an issue with their voicemail? Mine is indicating that there's a voicemail when there is not. I can't clear the indication either. I've done a hard reset on my iphone XR, but that hasn't changed anything, the red dot is still there. If anyone has a solution please let me know.
Thank You!
Other
06-15-2023 07:49 AM
@softech Yes everything is ok with the voicemail notifications now on both phones.😁
06-14-2023 07:03 PM
Thank You! I sent a message to a CS Agent, thanks to you!
06-14-2023 06:56 PM
the chatbot ticket is having problem for long time. Please message PM support instead:
06-14-2023 06:49 PM
Thank You! I did open a ticket but it didn’t go through. It said an error occurred. I will try again. Thank You for your help! I had one voicemail today and after I deleted it, the red dot went away. The second voicemail I got was when it didn’t go away after deleting the message. Maybe a VM reset will do the trick!
06-14-2023 06:37 PM - edited 06-14-2023 06:38 PM
@mern16 actually, 16.5 might be the reason that it broke the VM
We have seen at least one person with the issue and confirmed he/she on 16.5
But in fact, we have seen many people with this issue. We cannot confirm if iOS or PM is the problem. Some upgrade to a newer iOS and fixed it. Some have the same iOS, the older iPhone works but not the newer. Some have been working but since iOS update, it failed
you can try your luck by opening a ticket with PM support to reset your VM, some got it fixed after that, but not for some.
To open ticket with PM:
**Monitor your Community inbox (envelope icon on top right) after the ticket is opened. CS Agent will reply to you there
@Lieux are your two iPhones on the latest iOS now? the VM notification still work on one but not the other?
06-14-2023 06:32 PM
Yes, I have the latest iOS 16.5. Thank You for suggesting that!
06-14-2023 06:31 PM
@mern16 It’s an iOS issues I believe , have you updated to 16.5 iOS yet . May help
