07-10-2017 03:33 PM - edited 01-04-2022 02:19 PM
Hi,
I'm curious to know if my PM voicemail will still be reachable and functioning for people to leave me messages if I do Not have roaming while I'm travelling in the USA? What if I travel to a country where there is not even a PM roaming option to purchase? I'd like to know if I can at least check my voicemail at a later time even if don't have phone roaming capabilities while travelling. Thanks.
04-04-2018 10:08 PM
Not sure what tobacco you’re smoking @Mreekster, but your comments have nothing to do with this conversation.
By default, someone calling a public Mobile phone number will go to voicemail.
Pivking up one’s voicemail is easy, just make a call via a usable system, long distance, or web app, etc to your pm number, and away you go.
Email and roaming voicemail packs mean absolutely nothing here.
04-04-2018 04:21 PM
What I was told is if you do not buy a voicemail roaming pack and add just data, then you will not be able acces email and even worse no one can even leave a message. Ridiculous you add on and lose your service that you pay for
08-15-2017 11:03 AM
i had no problem checking my VM using google voice when i was overseas.
07-10-2017 05:55 PM
Picking up voice mail is easy peasy. If the Public Mobile service is not running, then calls will go straight to voice mail. To pick up the voice messages anywhere in the world, use an app such as hangouts to call back into North America for free, call yourself and intercept the voice mail system and you will be asked to enter password and listen to any available messages.
07-10-2017 04:52 PM
07-10-2017 04:44 PM
07-10-2017 04:32 PM
@In4Lb Load Fongo up on your phone and you can use a WIFI connection to call your own mobile number while away from home.
You can check your vmail by hitting either # or *.... can't recall right now.
It's free, and it works!!
07-10-2017 04:05 PM - edited 07-10-2017 04:11 PM
I found this. its from a few years ago for if you want to check voicemails
But i believe people should be able to leave you a voicemail. The calls will just be sent straight to voicemall since you will not have a US roaming add on, or other roaming add ons, ect.
Edit: Please ignore the above link, use this instead if you do want to access your voicemail while roaming
https://productioncommunity.publicmobile.ca/t5/Discussions/Voice-mail-from-United-States/td-p/142912
07-10-2017 04:03 PM
07-10-2017 03:55 PM
Thanks for the quick responses guys but to be clear, I'm more concerned about someone calling me & being able to leave a voicemail even if I can't check it. I'm not so concerned about ME being able to immediately call to check my voicemails. I want it to be recorded and be available for me to check ... whenever.
And I do not intend to leave my phone in Ontario & plugged in when I travel. Just want people to at least still be able to leave a vm. Appreciate the feedback.
07-10-2017 03:43 PM
My understanding is the vociemail is associated with the area code that you registered your phone in. So calling it while out of province is long-distance. And I don't think you'd be able to call it while out of country if you don't have an add-on that allows such call to your area code.
@In4Lb wrote:Hi,
07-10-2017 03:40 PM - edited 07-10-2017 03:42 PM
