01-05-2022 03:38 PM
I’m getting an error when trying to access my voicemail from my phone.. it will not connect
01-06-2022 02:31 AM
@darlicious wrote:+1 (000) 580 4001 (fill in your area code).
I would recommend against using the general term "fill in your area code" because there isn't voicemail access numbers in every area code, and just reference the Updated list of Voicemail Access Numbers. For example, according to that list, there is no voicemail access number with the following area codes, though certainly ones in area codes that overlay their areas:
236 249 250 343 365 367 416 418 431 437 474 514 519 548 579 604 639 672 709 742 780 782 807 825 873 905
01-05-2022 08:53 PM
01-05-2022 04:51 PM
Is the method of resetting the voicemail password in the self-serve and then using a different phone to do initial setup still a thing. So as not to use limited minutes. Otherwise of course with unlimited it wouldn't matter.
01-05-2022 04:35 PM
@WallyDee wrote:I’m getting an error when trying to access my voicemail from my phone.. it will not connect
Are you just hitting and holding the "1" on your phone dialer?
That feature should work.
Try rebooting or a reset of network settings.
You can also try calling your Voicemail Access number directly and see if that is any different.
Here is a list of the Access numbers, as posted by @Nezgar.
Find which one is your area and add it as your voicemail contact on your phone:
01-05-2022 04:00 PM
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
and try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
*what is meant by rebooting the device turn off and turn it back on.
review everything about voicemail Help Articles (publicmobile.ca)
and try to call your number from same device.
01-05-2022 03:56 PM
If you haven't set up voice mail here's how to do it courtesy of @Jb456 :
After you’ve activated, your voicemail is automatically ready to accept messages as soon as you add it to your account. It will play a default greeting until you set it up. Setting it up isn’t complicated:
01-05-2022 03:54 PM
How do you try to access your voicemail?
From mobile phone or from other phone calling voicemail number and entering PIN?
Did you set up PM voicemail at all? It has to be set up from your mobile phone not from other phone.
01-05-2022 03:51 PM
Did you set up your voicemail? Have you recently activated and/or ported in your number?
