09-08-2021 03:01 PM - edited 01-06-2022 03:19 AM
I was curious to know that how can I listen to my voicemails form other than my mobile phone.
Thanks and Regards
09-08-2021 03:34 PM - edited 09-08-2021 03:35 PM
You can call from another line, dial your phone number
once your greeting comes up, press the start key star * and enter your voicemail pin, to listening voicemail machine ....
if you don't have voicemail pin, you can go sign in to Self-Serve, Reset your pin....
09-08-2021 03:26 PM
@shahestates : And also dialing any of the voicemail access numbers from a non-Telus-family (maybe just cell) phone. Like 17785804001.
09-08-2021 03:10 PM
You can also access your voicemail from a landline or any other phone line, by dialing your 10-digit phone number, selecting ‘Send’ or ‘Call’ and then pressing ‘*’ to skip the system greeting.
