12-07-2019 01:22 AM - edited 01-05-2022 08:23 AM
12-07-2019 04:18 PM
threads merged
12-07-2019 02:16 AM
Your voicemail box can have 10 messages, whether new or saved. Each message can be up to 5 minutes in duration. After 10 days, a message, whether new or saved, is automatically deleted, unless saved. You do not have to wait until the 10th day to save a message (for another 10 days)
12-07-2019 02:11 AM
How many minutes can be recorded on voice mail?
12-07-2019 01:45 AM
After you’ve activated, your voicemail is automatically ready to accept messages as soon as you add it to your account. It will play a default greeting until you set it up. Setting it up isn’t complicated:
- Hold down the ‘1’ key on your phone keypad to dial your voicemail access number. Calling your own 10-digit phone number will also bring you to your voicemail.
- When prompted, enter a password between 4 to 15 digits long. Try to make it hard to guess, but easy to remember. It will be more secure if you avoid using numbers that are repetitive or sequential such as ‘1111’ or ‘1234’.
- Choose whether you want to bypass your password when calling from your own phone.
- Record your name, and a personalized greeting.
- When you’re done, hang up to end the call.
12-07-2019 01:36 AM
You can long press number 1 on your keypad or dial your own number. It will ask you to set up PIN number,password (optional), your name or number and personal greetings. Once you are done, you will have your voicemail box set up successfully.
Hope this helps
12-07-2019 01:35 AM
@Sunshine-754 wrote:How do I use my voice mail?
@Sunshine-754 Hold diwn the 1 from your device to access your voicemail and follow the prompts to set it up.
12-07-2019 01:26 AM - edited 04-05-2020 12:21 AM
Stay Safe!
12-07-2019 01:23 AM
Same question.
