01-15-2025
10:56 PM
01-15-2025
11:46 PM
computergeek541
When you receive a voicemail, should it not show on your account as an inbound call with time and inbound number calling?
01-16-2025 10:20 AM
01-15-2025 11:28 PM
i just checked mine, too. Look like if the calls got routed to the voicemail, you will only see a outbound calls to 4001 (VM), you will see another inbound entry before that
01-15-2025 11:27 PM
Hi…..had a voicemail sent to me today. My usage shows a bunch of outbound calls but no inbound. Trying to track the from # and time.
01-15-2025 11:00 PM
voicemail are show as outbound, your friend (who called you) will have the number shows as inbound, but then the call got forwarded to voicemail, and it will show as outbound, with the 4001 number
