Virgin to public
carmy82853
Hi, I recently changed from virgin to public amd I'm not receiving incoming calls or messages
@AE_Collector wrote:
How "recently"? Trying to recall the guidelines.... 2 hours to Port a cell # in and 8 hours to Port a landline in? Days to Port a VOIP number in. Outgoing should work right away
CWTA says 2.5 hours and 2 days.  https://www.cwta.ca/for-consumers/wireless-number-portability/#9
AE_Collector
How "recently"? Trying to recall the guidelines.... 2 hours to Port a cell # in and 8 hours to Port a landline in? Days to Port a VOIP number in. Outgoing should work right away but to receive calls and texts the Port needs to complete. This involves Virgin having to release the number after checking that you aren't locked in with them and don't owe them any money. Thus...it isn't instantaneous!
AE_Collector
ShawnC13
When you activated did you port your number?  How long ago did you join Public?  Your Port could be stuck and you will need the assistance of the moderators by clicking on the Question Mark in the bottom right and going through SIMon to create a trouble ticket.  If your port is stuck your Virgin sim will still be working and you can put that back in your phone and you won't miss any calls until the port is complete.
dabr
You porting may still be in process and not yet complete.  Give it a couple of hours, meanwhile try rebooting your phone.
