Video and group texts
th3Bird
First I can't make a call with google Meet. Is this too much for this network and they don't allow it? Second, I try to make a group text and I can only see the texts that come to me. The group cannot see my texts. That's pretty cheesy if they don't allow this. Up it puppet, do I have to show you guys how to run a telecom company?
Please fix this
1 REPLY 1
@th3Bird
PM does not restrict any app for data usage. You can also try using Google Meet on Wifi, does it work?  If it does not even work, it is a device issue, could be device incompatibility or version of the app
for Group text, what text app did you use?  If you have not used Google Message for it yet, try to install Google Message and set it as the default texting app.
If still does not work, try to update the APN as follow
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
           (might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
what phone do yo
