Using Saved Up Add Ons
Nazanadda
I am out of Data for this month, I have saved up 2GB, 1GB, 500MB, and 200MB available in my add ons. Do they automatically go into my account? How do I add these? Also, can we add more than 1 at a time?
hairbag1
@Nazanadda
good question...once your regular plan data is maxed out...then you're using whatever data add-on you have saved up. If you have several buckets of add-on data, it's tough to tell which saved add-on gets consumed first but they get used seamlessly until your next regular plan renewal occurs.
@Nazanadda  They will kick in automatically once your lab data is used up . And you should see them here as soon as you purchase them
simply try refreshing the page to check data plan / mins / add ons
@Nazanadda   Yes, the system will automatically use one of your addon on your My Account
To confirm you have the addon and avoid cache confusion, login My Account using Incognito mode once again and check
Also, make sure you phone does not have data limiter enbled
