Ushinning F200
Bastien
Will the Ushinning F200 work for public mobile?
8 REPLIES 8
@Bastien
As @computergeek541 has mentioned rogers has extended its support of 2G until December of  2020.
@darlicious wrote:
@Bastien
You will be hard pressed to find any provider in Canada that supports 2G any longer. Do you only require a flip phone or just a reasonably priced phone?
It's not difficult to find a carrier that supports 2g. Rogers still has a 2g network, although probably not for much longer. I agree with you that it's not a good idea for someone in Canada to purchase such a phone.
@Bastien
geopublic
@Bastien  if your looking for a flip phone it's got to support 3G bands B2 and B5. 2G phones will not work with Public.
brettster99
@Bastien
From what everyone has said. NO it will not work with Public mobile. You will need to find another phone.
Stay well
Dunkman
@Bastien
I did a quick google search.  Hard to find the specs on this phone.
Is your phone the following:
https://www.amazon.ca/Ushining-Phones-Unlocked-Canada-Phone/dp/B07V7XHVYZ
If it is this above phone, then it will not work with Public mobile/Telus/Bell since it is a 2G phone only.  PM does not support 2G.
gblackma
Sorry @Bastien  if this is the phone, https://www.amazon.ca/Ushining-Phones-Unlocked-Canada-Phone/dp/B07V3LYBJD it's a 2g phone and will not work here. Stay safe.
DOA
I believe that's a 2G phone, so probably not.
Alcatel makes  some flip phones that will work with PM.
