Ushining 3G flip compatability
pmdes
Is Ushining 3G flip phone compatible with Public Mobile network (Telus)?Looking at this phone for senior.
@gpixel  When specifications are listed as "Compatible Carriers
Band Mode: 3G WCDMA: 900/2100MHz or 850/1900MHz", this means that there is more the one version.  Assuming that website is providing the correct infiomation, the customer will need to ensure that right version is purchased.
Staliger
@pmdes Yes, it seems that this phone will work with PM. Good choice.
geopublic
@pmdes  If it has 3G bands B2 and B5 then it will work.
gpixel
@pmdes yes this phone is compatible with 3g
Compatible Carriers
Band Mode: 3G WCDMA: 900/2100MHz or 850/1900MHz,
2G GSM:850/900/1800/1900 mHz
Works with Rogers (Fido), Telus (Koodo), Bell (Virgin Mobile) or any carrier operates on above networks
