04-21-2020 07:11 PM - edited 01-05-2022 11:43 AM
Help I'm not able to add my data to my LG phone. What to do? What network to add it to? The phone store is closed and I tried YT with no help. Used phone... used to be Metro PCS. It says network mode...
GSM/WCDMA/LTE auto
Service
04-21-2020 07:38 PM
04-21-2020 07:37 PM
Got resolved
04-21-2020 07:36 PM
Helped 10000%
04-21-2020 07:36 PM
Do you know if data ever worked on it?
Were you able to send save receive mms messages?
It's most likely your APN settings, you a double check line by line.
Did your new plan start already?
04-21-2020 07:34 PM
@Eurydice wrote:Help I'm not able to add my data to my LG phone. What to do? What network to add it to? The phone store is closed and I tried YT with no help. Used phone... used to be Metro PCS. It says network mode...
GSM/WCDMA/LTE auto
@Eurydice are you a public mobile customer? From the sounds of your post it seems to me that you are not.
Do you have a self serve account? You will need this to add data to your phone.
Let us know a little more info.
04-21-2020 07:27 PM - edited 04-21-2020 07:29 PM
@Eurydice did you upgrade your plan or just put money in your account to pay for it? it is a 2 step process also check your self serve to see if it did indeed upgrade
04-21-2020 07:21 PM
Used phone
04-21-2020 07:20 PM
I upgraded my plan so I have data now. But it's not yet working.
04-21-2020 07:19 PM
Thanks I'll try it
04-21-2020 07:16 PM - edited 04-21-2020 07:36 PM
@Eurydice first check to see if your data is enabled. If it was, reset your network settings, restart your phone and try type 3 below of PM's apn settings.. Enter them, save, enable data and restart your phone. Stay safe.
04-21-2020 07:15 PM
What do you mean "add my data"? One could interpret that several ways. What are you trying to do?
04-21-2020 07:14 PM
@Eurydice Hello did you just buy a new phone or used please supply more information thank you
