Users Online
Mana
Hi,
In the previous layout it used to be so much easier to tell the users online.  It was helpful to see if there is a mod online.
Has this feature been removed or forgotten in the new layout?
Thank you.
11 REPLIES 11
matbasm
@LEGO, that's what the html code says.  It is possible that the system might be 'temporarily' disconnecting you, even though you don't notice it.  Or, perhaps it maxes out at some point.  Or...
LEGO
I am not sure if this is correct, I was online 9 hours and first number was only displaying 196.
Any more ideas?
matbasm
@LEGO,  I believe those are the minutes online & minutes idle.
LEGO
What are these two numbers listed beside each user?
@Mana you can just access it and save it as a bookmark, so that you can check it anytime you want with a button's click. It will be easier and faster.
Mana
Until PM make the user online link available, can we make this post with the user online link a "sticky" so that it's easier for everyone to access?
@Mana wrote:
thanks @NDesai
Do you know if there is a reason why the user online link is hidden?
Privacy reasons?
Nope, i don't really know why? Its accessible but just didn't add on the front page. I guess due to lack of space?
I will notify them and they will see if they can add it somewhere.
Mana
thanks @NDesai
Privacy reasons?
@Mana wrote:
Thank you, this help.
Does anyone know if there is an easier way to get to it like it used to in the old layout?
Not unless they put it on front page.
zhadj030
No it wasnt removed or forgotten, give me a second and I will bring you the link
Edit: It seems like it is not anywhere in the settings , here is the link :
http://productioncommunity.publicmobile.ca/t5/forums/usersonlinepage/
Dont ask me where to find it I stole it from a comment of @NDesai. So big thanks to him.
