User name recovery
ianburden
Why don't you allow retrieval of username?  You say you do, but the emails you send only offer a password change, which is no **bleep** use without a user name.  I have re-registered under a new user name, but that should not be necessary.
maximum_gato
@ianburden
If you can recieve the password reset for your other community account then search your email for any emails from the community that will be addressed to your username. Type the username in along with the password otherwise it returns an error if you use autofil when logging into the community.
@ianburden   If you're using your real name for the Community forum, then ask customer support to change it to just the first part of your name or something more generic altogether as this forum is open to anyone with internet access.
hi @ianburden if you need My Account, try tonreset password by putting your email
if unable to reset, submit ticket with CS agent
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
ianburden
I mean the Community Forum username.  The forum will not allow my email address.  My current username is indeed ianburden but that is new.  As I said, I had to re-register in desperation.
hairbag1
@ianburden
the username is simply your email address.
ed..
or did you mean Community Forum username ? yours is currently ianburden
