Used up data, purchased 1gb add-on but still nothing...what gives?
09-01-2017 01:22 PM - edited 01-04-2022 02:35 PM
09-01-2017 02:10 PM
@Luddite not really a fan of most 2 step music but sure why not?
09-01-2017 01:45 PM
@srlawren wrote:@imm1304 @Luddite aaaaaaand the dreaded 2-step strikes again! (I'm guessing. Seems the most likely cause of this issue, as it has been so many times in the past.) I sure hope that light at the end of the tunnel isn't too far off.
Dreaded two step?? You just need the right music playing to enjoy it!
09-01-2017 01:42 PM
09-01-2017 01:26 PM
Login to your account. If you see Available Funds equal to the add-on price just "buy" it again from those funds. Add-ons require two steps: first buy to add funds, second buy again to activate. Reboot your phone after this.
If that fails, or you have no Available Funds, click this: message to moderators to send a private message to the moderator team with your phone number and an explanation.
09-01-2017 01:24 PM
Its a 2-step process when you don't already have money in your account before purchasing add-ons.
Your money must be sitting in your account as "Available funds" now. Go ahead and check in selfserve. If this is the case, go to the add-ons page and purchase the data add-on you like... this time it will go through.
