08-10-2019 05:53 AM - edited 01-05-2022 06:21 AM
Hi there.
Just set my phone up. How is the us to canada calling, any issues. And how is the data in the us also. Thank you
cheers
don
08-10-2019 11:57 AM
That’s good yo hear @geopublic thank you. I’ll let you know how it works in Michigan and Indiana
08-10-2019 10:07 AM
@mellondon wrote:Hi there.
cheers
don
@mellondon Public Mobile in the US has roaming agreements with T-MOBILE and AT&T so coverage in most areas is good. If you are on the $60 you should be good to go.
Have a good trip.
08-10-2019 06:41 AM
Thank you for your help @Triguy
08-10-2019 06:25 AM
Here is more info about US roaming.
https://www.publicmobile.ca/en/bc/get-help/articles/us-roaming
08-10-2019 06:11 AM
Yes I do have the 60.00 so I should be good to go. Thank you
08-10-2019 06:05 AM
@mellondonIf you are travelling in the US and calling back to Canada, be sure to select the correct Roaming add ons (which lasts for 10 days).. or upgrade to the $60 plan which includes US Roaming. The advantage of the $60 plan is apparently the switch between US returning to Canada is seamless.. vs for the package if you return to Canada while the roaming package is still active you would loose SMS for 24 hours.
