12-16-2024 11:30 AM
Hello community!
I will be travelling down to the Baja, Mexico, each year at Christmas. I see that public now has a plan that includes Canada, the US, and Mexico. $29 can’t be beat!
Can anyone confirm if that might work well down on the Baja? Specifically, Cerritos and the area around it. Thanks!
Plans
12-16-2024 11:13 PM
@slusagm wrote:yes, it will work as long as there is T-Mobile or or Telcel there, which it has
The actual roaming partners that Public Mobile customers will end up roaming on while in Mexcio varies based on the region.
12-16-2024 11:44 AM
Thank you so much! Sorry, my messages were having trouble loading, so I asked a few too many times, lol - sorry about that!
12-16-2024 11:43 AM
@CoryZ wrote:The $29 isn’t for a certain amount of time…like, it won’t bump up to $65 in 6 months or anything like that?
No it won't. PM is honest, never do things like that. So, if you see the plan on your My Account, change to it
12-16-2024 11:41 AM
12-16-2024 11:38 AM - edited 12-16-2024 11:39 AM
you see the $29 plan?. change to it.
No, PM rarely change price. In last 5 years, they only changed price once or twice. That was only the $10 plan became $13 as it was the cheapest plan. No other plan they changed price in the last 5 years. So, once you have the plan, the price stays
12-16-2024 11:37 AM
Will the plan cost of $29 change after a certain amount of time?
12-16-2024 11:36 AM
existing customers won't see all the plans. Most of us don't see the $29 Canada/US/Mex plan. But if you see the $35 roaming one, it is still a great one to change to. Afterall, you are on the $34 now, just $1 more and it covers Mex
12-16-2024 11:34 AM
I currently have the $34 Canada/US plan, and was thinking to switch. Your answer helps me think I should.
I was looking for fine print, though. I can’t see that the $29 will ever change? What do you think?
12-16-2024 11:33 AM
the plan itself is very good with the roaming. But keep in mind, once you moved to this new plan, you might not be able to go back to your current plan. So, if you are thinking to use it for one month and change back, it might not work. But if you like the plan and decide to keep, it is a good one
