10-05-2021 01:46 PM - edited 01-06-2022 03:42 AM
10-06-2021 11:06 AM
Can you log into your Self Service account and confirm exactly what you see under "My Data & Add-ons"? It should list any Add-Ons you have, such as the US Roaming option.
If not, like others mentioned it's a two-step process:
Let us know if any of this helps! 🙂
10-06-2021 06:01 AM
@Mtbchick27 wrote:Hi I’m unable to activate a US roaming txt & talk plan??? I’ve tried 2 x
If you already had one of these addons that just expired and you are trying to add another one right after it, there seems to be a glitch with obtaining these back-to-back.
Therefore you may need Customer Support help to have it added for you.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them:
1 - Faster - Click the bubble comment circle on the bottom right-hand side of your screen,
or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower - Use this link to:
Private Message to Public Mobile Customer Support Agents (CSA)
10-05-2021 01:58 PM
Here is some info about US roaming add ons that should help you.....
Happy travels and Stay--Safe!
10-05-2021 01:53 PM
sign in to Self-Serve, to review your account, if you found at Available Funds: $ ?
Try To Purchase Add-Ons Using Your Self-Serve Account
To purchase Add-Ons using your Self-Serve account, follow these steps:
after you Add-on you have to do Rebooting your phone
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
Overview Of Add-Ons visit Here link.
10-05-2021 01:50 PM
Do you mind providing steps you did when buying add-on.
Purchasing an add-on after logging in into your PM account is a two step process. You need to load funds first and then purchase add on.
Those add-ons don't show up on the overview page. You need to click on Plan Details to see them.
https://www.publicmobile.ca/en/bc/get-help/articles/purchase-add-ons-through-611
https://www.publicmobile.ca/en/bc/get-help/articles/purchase-add-ons-through-self-serve
10-05-2021 01:49 PM
@Mtbchick27 are you in US now? If so, you are connecting to AT&T or T-Mobile? one provider might work better in one region but not other, try to connect to both carriers and see which one works
Also, you just purchase your Add-on now? does it show up on your My Account? Just want to confirm you bought it without any issue
