Us add on
mlangsam
My us add on is not  working
@mlangsam wrote:
I'm in New York I have a talk & text add on and I got t-mobile service and it's terrible I want to get at&t service but I can't
With the PM 15 Day US Roaming add-on...your only option is to connect to T-Mobile. AT&T no longer connect.
You should be able to receive texts without the add-on...you just won't be able to send texts without the add-on.
Text should work just fine with the add-on.
Just make sure to try connecting to T-Mobile and then give it a few minutes.
hi @mlangsam AT &T has not been working for some time.  Your only choice is just T-Mobile
if you have Talk roaming problem, try to enable VoLTE and see if it works, but it might not.  If not, you have to use the 2G network for voice calls
mlangsam
Hi @mlangsam can you connect to T-Mobile? if not, did you try manual connection?
and you are not rebuying the same add-on for this trip, right?
hairbag1
@mlangsam
additionally...make certain you have Roaming enabled in the phone settings.
@mlangsam you need to provide us more info for us  to help
which state and city you are at??
which roaming add-on you got? data? talk?
you were able to connect to T-MOBILE or not at all?
