01-20-2023 07:41 PM
01-20-2023 10:49 PM
Patience is the key on PM. Did a CS_Agent get back to you?
01-20-2023 07:57 PM
Care to elaborate? (without disclosing anything personal)
01-20-2023 07:55 PM
They didn't reply back and it is a account security issue
01-20-2023 07:54 PM
@Cathy62 did you check the Community inbox? no one reply? message them for update.
and what is the issue? mind to share and maybe we can help or suggest workarounds?
01-20-2023 07:45 PM
You did not reply to them? Or they haven't replied to you?
What seems to be the problem that you need them for? Maybe we can help.
01-20-2023 07:45 PM
If it's been more than 2 hours, submit another ticket.
01-20-2023 07:42 PM
